Old 06-02-2010, 08:51 PM
ridge_runner is on a distinguished road
Exclamation Cutting a 2"-4.5 UNC thread in a Mazak
Hello everyone! Found this site while searching for help cutting the above mentioned thread. I am cutting 2"-4.5 UNC little longer than 3" in a material known as B-16 (heat treated 4140?) on a Mazak using the ISO side of the controler. I am using Valenite inserts. I have two problems 1. is the the a a little chatter on the first three threads that I can not seem to get rid of. 2. on the back edge of the thread I have alot of rubbing with a poor finish being a result. I am not a 100% sure of what is in my G76 lines but I will post tomorrow when I see them again. I have changed my speed from 100 to 600 RPM and best results have been seen at 450 to 500 RPM but still have the rubbing on the back edge. Can somebody help me out here? Thanks
Old 06-15-2010, 12:55 PM
CoolhandLuke is on a distinguished road
I've done a job similiar to that. The trick is to lean on your tools, I was doing them in 6 passes, no spring pass. Make sure your tool is on center that should take care of your rubbing. I was using Iscar tooling, that's all I use. Just seems to form a nice chip. You're going to eat inserts with that material. Just it should give you a nice shiny finish. Coolant is king, get it in the hole and on the tool tip. I was cutting on the side of my insert and taking less...the deeper I went. I did best at 700 RPMs or so. You have to put a load on the insert, let me know how you make out.
Old 06-15-2010, 01:39 PM
Sometimes you can get rubbing because the thread angle is greater than the side clearance angle on the insert. You can get wedge shaped anvils (?) that replace the flat one in the holder, to tilt the insert a little for extra clearance.
Old 06-20-2010, 05:49 AM
ctate2000 is on a distinguished road
Use the Mazatrol side and program that tool to enter on 29 degress and cut only on the leading edge. Problem will go away.
Voice Your Opinion On "POLYMER CONCRETE FRAME" Thread! walter Polls 13 04-27-2012 07:19 PM
Index to "Epoxy-Granite machine bases" thread walter Epoxy Granite 13 12-01-2011 10:45 PM
Small CNC build thread 20" x 18" x 4" metalworkz DIY-CNC Router Table Machines 97 06-04-2011 01:21 PM
Need Help!- Mazak Variaxis 630-5X "Pallet Select Driver Alarm" Wheelz Mazak, Mitsubishi, Mazatrol 6 06-16-2010 07:23 AM
Replacing 8" Kitigawa chuck with a 10" on Mazak SQT15 BerkoB CNC Tooling 0 10-05-2007 12:39 PM
