Old 05-29-2010, 10:20 PM
wwendorf is on a distinguished road
Need to machine threads on a socket extension
Hi everyone,
I need to turn threads into a portion of a standard socket wrench extension. The material is chrome/vanadium. I need to turn it down from .482" to .372" then turn threads into it. I tried it tonight and promptly destroyed an insert.
Can anyone give me information on:
- Feeds and speeds
- type of inserts to use
- do I use coolant with it?
Any other information on how to do this would also be appreciated.
Thanks,
Wade
Old 05-30-2010, 10:33 AM
JimBoyce is on a distinguished road
It sounds like the turning tool broke before you even got to the thread. If this is the case grind the square off or grind it roughly round, even with a bench grinder and then finish turn. A spin indexer on a surface grinder would be a good alternative.
Try turning at 300 RPM (35 SFM) with a 0.002 Feed Rate. Like always these are just starting suggestions. Thread at 100 RPM (9 SFM) with flood coolant or cutting oil applied with a brush. Good rigidity is very important with this type of work.
Welding a bolt into a socket may also be an alternative.
Old 05-30-2010, 11:19 AM
Just for information sake, I was trying to turn it at 1000 rpm with a feed rate of .002 and a DOC of .015.
Wade
Old 06-01-2010, 08:51 PM
Thanks for the info. I turned it at 400 rpm's and it worked.
Thank you for the help!
Wade
MT5 shank to R8 socket sleeve veggiedog General Metalwork Discussion 3 02-04-2009 03:55 PM
Where can I get this style ic socket stock? samco General Electronics Discussion 1 10-23-2006 07:35 PM
Machining an R8 Socket Woodie1 General Metalwork Discussion 2 05-26-2006 02:47 PM
DP4/TT1 socket drawing Michael M AjaxCNC Control Products 0 01-29-2006 01:31 PM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
