Old 05-19-2005, 03:55 AM
FabCNC is on a distinguished road
PCB milling
Hi to everyone!
This is my first post here, and honestly I don't know if this is the right section... (excuse me for now that. For now I'm a bit confused with this big place!).
My question is simple:
From some months I'm engaged to build a small cnc milling machine to realize my PCB hobby projects.
Over the net I find some ideas about mechanics and control electronics.
By the time, I'm searching some software solution to control the system, but here comes some trouble:
I use "eagle" to create my electronic projects... this application has got a CAM processor with Gerber, HPGL, Excellon, ecc. output.
But when I import this output to some CAM soft, like Kcam, it is not well reproduced.
Can anyone has some experience (and than some ideas) to realize:
PCB track "de-contour" or some right transformations?
Well export-import drill file (for holes for "Trought Hole Technology")
Some tested procedure for doing that?
Thanks a lot and excuse my bad english!
Fabrizio
Old 05-19-2005, 04:41 AM
abasir's Avatar
abasir is on a distinguished road
Fabrizio,
No need to use the CAM, just download the ULP (GCode.zip) from link below and run it. So far no problem with KCam.
http://www.cadsoft.de/cgi-bin/downlo.../userfiles/ulp
Inside the .zip there are 4 files: for PCB outline, PCB track normal, PCB track mirror image & for drilling gcodes. Have fun...
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 05-19-2005, 07:03 AM
Thanks, man
this seems very helpful!!
I will try this ulp ASAP...
Old 05-23-2005, 08:07 PM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
FabCNC,
DeskCNC is the best I've Found So Far.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 05-24-2005, 05:35 AM
G-code.ulp Works great with OUTLINES in Kcam!!
But have some problems with drill g-code...
I never try DesKam... I will search for it and try...
Thanks for now!
Fab
Old 05-24-2005, 07:44 PM
abasir's Avatar
Originally Posted by FabCNC
But have some problems with drill g-code...Fab
What's the problem
The GCode produced uses G82 (Drill & Dwell). IIRC, KCam supports the G82 so shouldn't be any issues.
Spindle speeds for PCB milling CactusChip General Metal Working Machines 15 04-20-2007 03:54 PM
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
pcb milling dberndt Employment Opportunity 3 01-03-2005 08:44 AM
Where to buy CHEAP PCB milling bits abasir General Electronics Discussion 12 04-17-2004 09:14 PM
Cutting tool shape for PCB milling NeoMiller General Metal Working Machines 2 11-13-2003 11:09 AM
