I'm modifying a taig lathe to turn a large diameter (12"+) wheel and since the motor is small and I will use step down pulleys to increase the torque but of course this will slow the speed of the material turning... Any disadvantages as far as quality of the cut, heating up, noise, etc... that I should be aware of while cutting a round part (out of steel) that is turning so slowly? (BTW, I realize I will be needing to take small amounts of material off at a time) Thanks in advance! |
| The "SFM" (surface feet per minute) or speed of the material surface relative to tool is what you are looking for. The same applies to any cutting operation, be it on a lathe, mill, shaper, saw, drill... Use your google-fu to find the recommended speeds for the material you are cutting, and the type of tool you are using (HSS vs. carbide) |
| Yes, but will a slow speed in itself cause major problems? I'm not looking for efficiency, I am already expecting to take of minimal amounts at a time, I'm wondering if the fact that the wheel will only turn 200 rpms or so will cause some obvious problems that I'm not aware of yet...? Thanks! |
| I think the best answer I can give you is "sometimes". Most of the time, slow is ok. If you are using carbide cutters, they sometimes like higher speed and will give a better finish than at lower speeds. Not knowing what it is you're making, that's the best I can do. |
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Need Help!- Feed rate and rpm's | vivagolf | CNC Machining Centers | 4 | 10-10-2008 12:41 PM |
| New Machine Build- Does size matter ? | Tempus Fugit | DIY-CNC Router Table Machines | 2 | 10-08-2008 08:46 AM |
| How many rpm's is this spindle spinning? | Apples | General Metal Working Machines | 7 | 03-14-2008 02:40 PM |
| Do measurements really matter? | deleteallusers | Linear and Rotary Motion | 2 | 02-10-2007 09:37 AM |
| More RPM's from a V2XT | Lasershop | Bridgeport and Hardinge Mills | 11 | 11-09-2005 09:18 PM |
