Old 05-24-2010, 12:28 PM
thedude710 is on a distinguished road
Edge Finder Question
Hi All,
I have hopefully a simple question but after searching this forum for a while I couldn't find the answer.
I have a K2 table top CNC with a Bosch Colt router. The slowest it runs is ~10000RPM and I only have a 1/8" and a 1/4" collet for it. I need to find an edge finder that will fit in one of the collets and won't go crazy at 10,000RPM. I found only 1 mechanical edge finder from Fisher that could fit in a 1/4" collet but the router spins too fast and the edge finder always stays off axis (and goes out of control).
What other options do I have? I know there are electronic edge finders and test indicator dials. Are there any that fit in a 1/4" collet? Thanks in advance for any help!
Old 05-24-2010, 12:56 PM
wbaklanoff is on a distinguished road
If the motor of the router is a universal type (series wound with brushes) you can slow the rotation to around 1000 rpm (no load) with a speed reducer available at Harbor Freight or other such store or you could adapt an incandescent lamp dimmer switch. To be on the safe side, remove the speed reducer/dimmer from the circuit if its rating is less than that of the router. Think approx 750 watts per horsepower.
Old 05-26-2010, 11:56 AM
plastibob is on a distinguished road
could you use an electronic edgefinder or a 3d Taster?
Edge Finder Ashish B CNC Machining Centers 14 09-13-2009 03:51 AM
Need Help!- edge finder bbrown2005 Calibration & Measurement 3 02-12-2009 07:18 PM
Question About Edge Finder FLUTE HEAD Machine Problems, Solutions , Wireless DNC, serial port 16 09-29-2008 01:21 AM
Edge finder davehall General Metal Working Machines 1 09-28-2008 07:24 AM
Edge finder eggo Australia, New Zealand Club house 3 08-04-2008 10:57 AM
