Old 05-17-2005, 10:41 AM
Deviant is on a distinguished road
Supplier for Octagonal tube/barstock
Anyone know an online supplier?
Looking for around 1.25-1.5" octagonal tube.
Thanks,
Old 05-17-2005, 11:53 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
You should be able to source it through your local steel supplier.
McMaster - Carr has it though http://www.mcmaster.com/ctlg/DisplCt...tlgEdition=111
Oops ther smallest is 1 3/4
www.integratedmechanical.ca
Old 05-17-2005, 12:21 PM
ah, meant to add.
Looking for the octagonal in aluminum.
I haven' had alot of good luck with local suppliers.
Old 05-17-2005, 04:04 PM
jgro's Avatar
Gold Member
jgro is on a distinguished road
You could try here: http://www.lowcostmetals.com/
jgro
Old 05-17-2005, 04:21 PM
2muchstuff is on a distinguished road
Octagonal bar stock is easy to find but I have never seen it in tube that large before. That doesn't mean that it can't be found. Try Googling "Shapiro Supply", they have a lot of strange stuff. They have more than what their catalog shows.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 02-11-2011, 11:24 PM
LAX LAX is offline
LAX is on a distinguished road
Lacrosse Shaft?
Sounds like the dimensions of a lacrosse shaft. If you find this in 7055 Aluminum alloy, let me know. I'm looking for the same thing. Hard to believe that $2 worth of metal sells for $100
canadian supplier threaded rod? rickkun DIY-CNC Router Table Machines 4 02-12-2006 11:50 AM
Looking for a supplier CNCBoss CNCzone Club House 4 02-21-2005 08:36 AM
Metal Supplier in Colorado Springs - Where? creative_mind General Metalwork Discussion 3 02-02-2005 01:03 PM
Supplier of Plastic Hex Bolt Covers - Where? creative_mind CNCzone Club House 3 12-30-2004 09:23 AM
End Mill Bit Supplier? UCFMems General Metalwork Discussion 3 08-11-2004 02:21 PM
