Here's the deal...I am turning parts on my cnc lathe and parting them off. The threads are thru and I want to deburr the cut off side. When I do it, it throws a burr into the threaded hole and a bolt won't start. I don't want to tap them. Is there a tool to use to deburr hole so i don't have to retap them?? I have 12k parts to run. Thanks all |
| I assume your cutting ID threads? cut a relief in the back side before you part it off. the best way is to chamfer, bore and do relief cut thread chamfer Bore and relief (drypass) Cut thread (dryPass) part off. end no burrs what type of material |
| Could you put a grub screw in before you part off (less than the thickness of the parted off part obviously), part off, de-burr then screw the grub screw in and out? You could use one of them battery hand held drills with a hex head attachment to speed it up. Or what about a cone shaped grinding thing- would that leave a bur?, you could make a fixture to locate them on the drill press and zip through them.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| CoolhandLuke Do like the other posts have said or simuilar , with a boring bar that the insert is on a 30deg or what angle, you want to cut on the inside of your part, Do this in before you thread it, & then part it off
__________________ Mactec54 |
| The thread is 5/16-24 so it would tight to get a boring bar in and relieve it. The part is 2.125 long so I would have to hang it out a good ways with a really small diameter. I have tried a burr set. Like the other guy mentioned...the one that you typically use in a diegrinder. Tried a carbide countersink RH chatterfree 6 flute HSS countersink single and multiple flutes. The only thing I can think of is if they have a left handed deburring tool where it peels the chip out instead of down in the threads. Retapping sucks even though we have a tapomatic on a drill press. I don't want to have the extra 5 seconds in them LOL. |
| Suggest you change the parting tool front clearance so that the parting off bur is on the chuck side not the part side. This should leave a square ended treaded hole and there may be a bit of a tear as the parting tool breks out on the last bit of the thread crest. This is easily removed with a snail type counter sink which could be a simple hand held routine - one quick twist - depending on how many you need to make! Regards - Pat |
#10
| That still doesn't get me anywhere. I want to run the part on the machine and have it tap them. Get them out of the parts catch and burr and i'm done. I want to eliminate retapping them. I have to put a small chamfer on them so the screw starts and goes in and without a burr. |
#11
| This might be a situation where the costs of a single setup aren't worth the gains. Fewer setups aren't always faster. Estimate your net handling time to do these in two ops. It might be faster than dicking around with deburring after the fact. |
| Lathe - threaded hole/threaded pin, not concentric when bolted together!? | The Aspirator | General Metalwork Discussion | 13 | 04-17-2010 11:28 AM |
| MR DEBURR | mlj01 | PlasmaCam | 0 | 05-19-2009 03:43 PM |
| Threaded hole | larry53 | SolidEdge | 12 | 10-02-2007 05:39 PM |
| How do you deburr ID Delrin AF Threads | phoodieman | General Metalwork Discussion | 0 | 05-31-2007 03:08 PM |
| How's your hole........threaded | trubleshtr | DIY-CNC Router Table Machines | 0 | 04-03-2005 11:42 AM |
