Old 05-14-2010, 11:57 AM
jweaverlingtpa is on a distinguished road
XYZ Interpolation
I'm trying to create an arc in a block of aluminum that has a radius in the Z axis, but also moves in the XY.
I'm using a Haas VF2. I thought that using G18 G03 with X, Y, Z and R defined. It did not.
Can someone help.
thanks.
Old 05-14-2010, 02:15 PM
This question came up in this thread:
http://www.cnczone.com/forums/showthread.php?t=82663
I did some experimenting with my MiniMill and describe what I found in post #17.
When you try to program a Z radius along the X axis it works.
When you try to program a Z radius along the Y axis it works.
When you try programming a Z radius across both X and Y something seems to go funny.
Old 05-17-2010, 08:06 AM
Thanks Geof!
I read through the post and found the section where you tried to do an ellipse about the YZ. That gave me the info i was looking for.
heres what i ended up useing,
G18 G03 G91 X-0.2795 Y-0.113 R0.215 D02 F2.
Thanks again.
helical interpolation 15m Goran P. Fanuc 4 11-16-2011 01:31 PM
cylindrical interpolation rajeshtikar General Material Machining Solutions 12 03-31-2009 12:01 PM
Cylindrical interpolation davisboys Fanuc 7 01-01-2009 08:46 AM
vr-11 A & B interpolation tarponicus Haas Mills 1 11-05-2008 03:48 PM
interpolation rimcanyon General Electronics Discussion 9 04-08-2004 01:10 AM
