Well, I got into this a bit over my head....but I am trying to make the best of it. I purchased a Haas Superminimill last year and finally have got the thing setup where I can cut something! I have a person coming over to show me the ropes and cut some stuff..... I ordered the stock today I would need.....and less than $75 worth a metal turned into $200+ just to have it cut into blanks! So, I need to be able to cut 3/16 inch Aluminum plate and 2.5 inch round Aluminum Rod.....possibly up to 3.3. I can't really afford a band saw. I did some searching and found something about Chop saws.....and some type of triple chip blade? So, if someone can point me in the direction with a link to whatever I need and such, I would appreciate it.....I just need to get this thing up and running, so I can make some money! Later EddieO |
| EddieO, Harbor Freight has a bandsaw on sale for $199 http://www.harborfreight.com/horizon...saw-93762.html If you use a coupon you may receive an additional 20% off. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| I actually bought one of those long ago....took forever and a day to cut through 1/4 inch copper plate.....and the blade wasn't looking to great afterwards....I gave it to my dad.... I am hoping to find something that will cut them fast and fairly accurate...the local metal places, are basically triple charging on the metal to cut it.....and even then its 1/8" tolerance.... What interests me is these miter saw/chop saws with a special blade.....everyone makes it sound like they cut pretty fast.... Later |
Seriously impressive tool! - not outrageously expensive either! |
a table saw with a carbide tipped blade. Seriously. I cut 1" plate, 2"x3" bar stock, 3" rounds and more without any problems. The carbide blade will slice through 3/16" aluminum like a hot knife through butter. The blade will last a long time, and all of the 5 blades or so that I have used up were killed because they got gummed up with chips. I learned to either spray some WD-40 on the blades, or a candle. This keeps the chips from sticking... I've never worn out a blade from wear and tear alone. I have gone through 3 table saws, but I have just been buying the cheap $69 Ryobi one at Lowes/Home Depot - switch broke on one, motor burned out on another. But I cut a LOT of aluminum on them before they died. You would be amazed at how well a table saw will slice through aluminum. Just wear a face mask to avoid hot chips hitting you and distracting you. |
| That Harbor Freight bandsaw will cut a lot better than what you experienced if you set it up right and buy a quality bimetal blade for it. If you want a chop-style saw, I use a DeWalt Multicutter: They're fast and leave a decent cut. While they cut faster than the bandsaw, you have to attend to them, whereas the bandsaw can be left on its own while you do something else. Use a workstop that swings out of the way, and put a bucket under the bandsaw and you can cut stock all day, stopping occasionally to feed it some more stock. Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| I just purchased a Grizzly portable metal bandsaw with stand as I needed something for larger stock. I have been using a Metal Devil blade in a Craftsman 7 1/4" miter saw. It worked great until I bent the blade. I also used the blade to cut some plate which worked great. I cut 1.25 x 1.5 6061 aluminum bar with no issues. A few lessons learned: 1. Clamp all work down. 2. Bring the blade down real slow. 2. When you are done with a cut, keep the saw pressed down until the blade stops. (I bent the blade lifting the saw up, and 1.25 round stock piece rolled under and caught the blade, I also have a small hole in the wall) For plate, I recommend the Metal Devil blade on a circular or table saw on up to 1/2" plate works great. http://www.mkmorse.com/ Dave |
| I went ahead and ordered the evolution saw. After watching the video, I am pretty sold that it will do the job for me. I ordered the aluminum blade. I am gonna buy a nice little bench to mount it to and then make some jigs to hold the parts and measure them so I can pound them out quickly and safely. Thanks for all the help... Later EddieO |
| Cutting 1/2 x 4" aluminum bar stock | KSky | General Metalwork Discussion | 13 | 07-14-2011 02:54 AM |
| Where do you get aluminum stock? | slashmaster | General Metalwork Discussion | 9 | 03-08-2009 11:07 AM |
| Aluminum Stock- Available Suppliers? | mtuckf | General Metal Working Machines | 9 | 06-05-2008 12:59 PM |
| Facing aluminum stock- tool to use | leberen | General Metal Working Machines | 26 | 08-05-2006 10:02 AM |
| Where to buy stock aluminum? | tipschips | Benchtop Machines | 6 | 08-01-2006 01:24 AM |
