Old 05-14-2005, 07:50 PM
*Registered User*
ChrisJ is on a distinguished road
Rust on Cast Iron
Looking for a good remedy to remove surface rust and the rust stain that is underneath the rust spot on cast iron.
I am going to try a brass brush with some solvent (gas, kerosene or other) but I figured I would ask the group here first. I am hoping a brass brush will not scratch the cast iron since some of the spots are on a smooth area of cast iron.
Your suggestions please.
Chris
Old 05-14-2005, 08:12 PM
murphy625 is on a distinguished road
Paint Stripper...
Sandblasting or more gential Plastic Blasting works great..
Depends on how bad the rust is..
Murphy
Old 05-14-2005, 09:06 PM
Nono's Avatar
Nono is on a distinguished road
Ever considered Naval Jelly? You Can buy it at ome Depot or Lowes...Once clean use johnsons paste wax to seal against moisture...
Old 05-15-2005, 06:38 AM
*Registered User*
Thank you both for your suggestions.
I will let you know how it went after I try one or both methods.
Chris
Old 05-15-2005, 08:58 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
Chris:
Please do post your results. I have a similar situation; I cleaned some parts with paint thinner and did not immediately oil coat them (my bad ). The next morning there were several rust spots. The rust cleaned up with just light machine oil and 0000 steel wool but left dark stains. I would be much interested in any successful means of removing the stains.
robotic regards,
Tom
"Do you think if we licensed poets, that they would still take poetic license?"
- - Dennis R. Ridley
Old 05-15-2005, 09:42 AM
ger21's Avatar
I've used this Rust-Free stuff for my table saw and all my other tool tops, it works great.
http://www.eagle-america.com/html/ca...oup.asp/334293
Then cover with Top Coat to prevent rusting.
http://www.eagle-america.com/html/ca...oup.asp/332788
Old 05-15-2005, 09:50 AM
Gold Member
lerman is on a distinguished road
Chris
If gasoline doesn't work, try ether. Be sure to smoke while you are using it. :-)
Gasoline is good for running cars. And reasonably safe. But it should NEVER be used as a cleaner, solvent, for washing your hands, etc. It should never be stored indoors.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 05-17-2005, 08:33 PM
*Registered User*
I guess using gasoline to lubricate the double sided tape on the end of my golf clubs when I am regripping is a no no also?
Well I tried both a paint stripper and a version of naval jelly. The naval jelly worked very good. Paint stripper didn't work so well, but it could have been my technique. I bought the naval jelly from a automative store. It was labeled as a rust remover but I believe it has the ingredient(s), like phosphoric acid that are listed in naval jelly.
Only thing I found was that the stain went from a rust color to a white color (cloud). Guess it is better than it looking like rust. I could not remove the white stain with either a brass brush or steel wool.
To seal the cast iron, I already had some Rust inhibitor by "Crown". I believe it is lanolin based. I think it works really well.
Chris
Old 05-17-2005, 09:57 PM
ger21's Avatar
I use lacquer thinner. Golfsmith used to sell Naptha I think for regripping, before they came out with the environmentally friendly stuff that doesn't work very good.
Old 05-17-2005, 10:17 PM
fyffe555 is on a distinguished road
I can second Ger's recommendation of RUST-FREE, it did an excellent job on my PM66 table top. Boes works well keeping it rust free even in a FL climate.
As an aside, is the cast iron a working surface or just cosmetic? If its decent quality cast then you can make it highly rust resistant just by heavily burnishing it with a wire brush. Loads of old bridges where treated this way, or to keep on the enviromentally incorrect theme, black leading the cast was a method of maintaining cast iron stoves for generations... All of it was bloody hard work though....
Andrew
Old 05-18-2005, 01:06 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
For smooth surfaces such as a machine table or drill press column - Once the rust is removed, try waxing it two or three times in a row with a carnuba-based car wax.
No kidding.
Scott
bending cast iron Goofour Bending, Forging,Extrusion... 16 10-21-2006 12:38 PM
rust prevention coolman General Metalwork Discussion 2 01-22-2005 11:32 PM
Cast iron milling problem kdoney General Metal Working Machines 2 10-06-2004 01:11 PM
Multimeter and soldering iron shopping. Konstantin General Electronics Discussion 3 08-26-2004 09:03 AM
Iron Fever Expo August 14-15 CNCadmin Trade Shows and Events 0 08-12-2004 07:48 AM
