Old 05-11-2010, 02:19 AM
Micro Milling is on a distinguished road
Are all small end mills carbide?
Was looking for some 1/32 or .020" to .050" end mills and have noticed they are all in carbide. Thought I would go cheap and get some HSS ones.
Is there a reason for this? I heard carbide needs high RPM, will that matter in my mini-mill with max of about 2500 RPM?
ALso a side question, will the cobalt M2AL end mills work fine with lower RPM? I can pick those up cheap, so thought I would get those instead of HSS.
Old 05-11-2010, 03:27 AM
serriadh is on a distinguished road
If you're using very small end mills you'll need high speed regardless of the material. At 2500rpm, a 1/32" end mill will be moving its flutes at something like 20 feet per minute, if my maths hasn't deserted me entirely.
(1/32" * pi = 0.098" circumference * 2500 rpm / 12" = 20.45)
Google for recommended surface speeds. One source suggests 50fpm for steel, and 250 fpm for aluminium... thats 6100 and 30500rpm respectively! You're not going to get a good surface finish or tool life at only 2500rpm, regardless of what the bit is made of.
Old 05-11-2010, 12:54 PM
You might try investigating HSS single lip end mills and engraving tools. Company I worked for used them to mill small features in dies. Down to .007" Rad. @ 40,000 rpm. Worked fine.
Dick Z
DZASTR
Using Resharpened Carbide End Mills Packers Metal Working Tooling 36 03-20-2009 11:21 PM
Carbide end mills worth it? mrcodewiz Benchtop Machines 34 11-09-2008 09:12 AM
Running carbide end mills in side-lock end mill holders Cory General Metalwork Discussion 41 01-14-2008 07:55 AM
Down-cut carbide end mills????? SkipW General Material Machining Solutions 9 02-16-2006 02:44 PM
Inexpensive carbide end mills? saturnnights General Material Machining Solutions 15 02-12-2006 10:05 AM
