Old 05-06-2010, 09:11 PM
Cartierusm is on a distinguished road
Help Milling Copper Tube on CNC
I need to make some tube miters on 4" copper tube and the tube it has to fit is 8" so using a hole saw is out, that's normally how I do it.
I set up a program to cut the 4" copper tube and have a good rigid way of mounting it in my vice. The problem is copper doesn't mill easy as it being a hollow tube it vibrates and seems to mill hard. I tried a 2 flue solid carbide bit 6" long and it shattered, obviously I tried to mill too much at once.
I'm going to use a 4" hole saw first on the mill and get rid of the bulk of the material then use do a regular cnc program.
My questions is what type of bit should I use, IPM and RPM. Originally I used the solid carbide 2 flute, 1" DOC, 10 IPM and 2500 RPM.
Thanks.
Old 05-07-2010, 10:52 AM
djr76's Avatar
djr76 is on a distinguished road
can we get a picture or drawing?
Old 05-07-2010, 12:44 PM
I think I got it worked out.
I used a 4" hole saw to cut away most of the material leaving .03 on the tube. Then used the hole saw at two other points to remove move material. I ran it at 800 RPM and a down speed of around 3-5 IPM.
Then I used a 4 Flute TiN Coated 5/8" End Mill with my program, 2000 RPM, 5 IPM and 1/2" DOC. It was slow but worked and the bit seems to still be relatively sharp.
Old 05-08-2010, 12:48 PM
djr76's Avatar
if you are cutting a hole in thin wall tubing, a smaller cutter would run better interpolating the hole out to finish size.
Old 05-08-2010, 01:54 PM
Not quite sure what you mean, smaller as in smaller than the 5/8" EM I'm using?
I was using the 4" hole saw to remove the bulk of the material then using a 5/8" to finish it off with a tool path I created. Did you mean smaller than 5/8" EM? I can't really go smaller as it needs to mill down pretty far.
Copper milling? jinu117 General Material Machining Solutions 4 11-29-2007 05:49 AM
Milling copper Burn General Metalwork Discussion 16 04-26-2007 02:18 PM
Tips for milling copper anyone ? DJ Morrow General Metalwork Discussion 16 09-27-2006 07:37 AM
milling copper (99%) nervis1 General Metal Working Machines 3 09-26-2004 06:34 PM
Copper milling eponyme-le General Metal Working Machines 16 06-11-2003 02:07 AM
