Old 05-03-2010, 04:54 PM
Frogblender is on a distinguished road
Thumbs down FLUMMOXED: Milling thru leaves sharp edge. Fix how?
Howdy... The picture shows the cross-section of my setup for cutting parts. 6061 stock and 6061 sacrificial plate are held down with screws (not shown). My tooling sequence is:
1) Slot with EM. The slot extends about .015" into the blue sacrificial plate (see pic).
2) Use 45° chamfer to give a nice edge on the top.
The problem: the bottom edge of the finished parts is very sharp. How do I take the edge off a little? .003" would be plenty.
Here's some things to consider:
- the top of the part is already cosmetically finished, so I don't want to tumble the part.
- flipping over the part and running the chamfer tool: problems with registration, and marring the cosmetic side.
- Would like the bottomside edge removal repeatable over hundreds of parts.
Any ideas would be greatly appreciated!
Old 05-03-2010, 05:13 PM
Kipper's Avatar
Kipper is on a distinguished road
What is the first cut into the sacrificial plate like? If good can you chamfer the underside while still in the fixture....
Keith
Old 05-04-2010, 10:30 AM
Not sure what exactly you're asking. The cuts are nice and clean. When the EM cuts the sacplate, DOC totals about .040" (.015" is the sacplate, .025" is the stock).
What kind of bit would be used?
Old 05-04-2010, 11:08 AM
djr76's Avatar
djr76 is on a distinguished road
a dovetail cutter would do the trick
Old 05-04-2010, 11:37 AM
Kipper's Avatar
Thats the ticket!
Keith
Old 05-04-2010, 12:00 PM
[QUOTE=djr76;771132]a dovetail cutter would do the trick[QUOTE]
Hmmm.... the dovetail does look pretty.
FYI: here are some I found small enough to fit down my 1/8" slot. Not particularly cheap, though:
http://www.harveytool.com/products/p...vetail+Cutters
Old 05-05-2010, 08:25 PM
ctate2000 is on a distinguished road
Try a simple burr knife. $12 from MSC.
Old 05-06-2010, 10:55 AM
djr76's Avatar
oi, I didnt realize it was an .125 slot, that can be a bit of a pickle. A small file, lightly buff it on a pedestal buffer, or with what ctate2000 said.
Sharp sv24-12 with 0i mate control milling 3D zosotd Sharp CNC 5 11-30-2010 02:12 PM
Need Help!- Sharp edge on Cut & Auto Torch Height Control nfrees114 Torchmate 3 02-25-2010 11:30 AM
SHARP EDGE Paulo E. Mechanical Calculations/Engineering Design 1 04-27-2009 05:38 PM
Need Help!- Sharp SV 2412s Question Thd Milling arcticigloo Sharp CNC 2 04-12-2009 07:00 PM
