Old 05-03-2010, 09:46 AM
stuby is on a distinguished road
Turning Threads off Grade 8 Bolts?
Hey guys, hows it going? I am in need of some assistance. I am trying to turn down the threads on some grade 8 bolts, 700 of them to be exact. We put it on our rockwell tester, and we're getting 58-60 Rc. My tooling is just not having it one bit. I can only get through about 4 parts before my inserts are done, however the finish I am getting is immaculate. I am running 850 RPM at .0055" per revolution feed (Im on a lathe, if you didnt know) and I am using a KC850 grade insert. Should I be using a HSS cutter or is this stuff just going to burn carbide being as nasty as it is? I just want to make sure my feeds/speeds arent too far out of whack before I go and buy some more expensive inserts. Thanks ahead of time for the help guys, you always come through.
Old 05-03-2010, 10:42 AM
Thawk53 is on a distinguished road
What diameter are the bolts. Can't figure your surface footage without that.We have excellent results in steel at 54 Rc with Kennametal KC9110 grade.
Rick
Old 05-03-2010, 01:08 PM
juergenwt is on a distinguished road
Stuby - Pls. check your Rockwell tester. 58-60 Rc sound unreal. Like 53 said: what dia? Unless those are some very special bolts - you should not have any problems.
turning 430F grade stainless steel callganesh General Metalwork Discussion 2 11-03-2008 03:25 PM
Turning NPT Threads TGSTP CNCzone Club House 0 10-04-2007 06:07 AM
Eccentric bolts JerryFlyGuy Mechanical Calculations/Engineering Design 14 01-17-2007 10:01 PM
HSR rail bolts? Gnu Linear and Rotary Motion 8 01-10-2007 04:24 PM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
