I've got a problem.... I am trying to come up with a solution for machining a 97" long part using a vertical mill with a 84" maximum travel in the x-axis. As of now I am using multiple clampings in order to face both ends to length and drill two holes. I have thinking about using m-code relays to shift the part laterally along the x-axis in order to reach both ends. I am working with extrusions and tolerances are quite large so precision is not extremely critical. This sounds like a fairly easy task, however being a newbie I have never worked with m-code relays before. Has anybody had any experience with this? Other than purchasing a new machine, or using multiple clampings, are these my only options? Thanks, |
| I used to machine features into aluminum extrusion in excess of 100 inches on a table only 40 inches wide, sometimes requiring 3 shifts. My tolerances were wide also, so I just scribed a center line in the aluminum and lined it up visually with a full-point countersink in the spindle. After I shifted the part, the c-sink was programmed to rapid down, then feed to almost contact the scribed surface so I could line it up and re-clamp. I know you're dreaming of a more automated solution, I did too, but I thought maybe my scribe-and-shift method would be less headache than whatever you're currently using. |
| Is there a word for moving a part when there isn't enough X and Y axis? | slashmaster | General Metalwork Discussion | 11 | 05-31-2010 01:03 AM |
| moving a part in the cambam field | wantsout | CamBam | 3 | 10-22-2008 11:11 PM |
| CNC & Hydraulics | anthony | Mechanical Calculations/Engineering Design | 23 | 05-05-2007 10:48 PM |
| Hydraulics:HELP!!! | IcutPoly | Fanuc | 3 | 11-12-2006 05:01 AM |
| Moving a part: which method | originator | Linear and Rotary Motion | 0 | 11-02-2006 11:19 PM |
