| I cant remember the name of it but I use it to engrave. Its a .125" dia carbide blank ground to a point with 1/2 the diameter ground away. essentialy a single flute. Msc carries them. you could simply machine the criss cross pattern to get the effect. I can tell you exactly what its called on monday
__________________ myspace.com/1metalmorphose |
| What about taking a tap that has the correct pitch to match the knurl you want, and grind all the flutes down but one. You would have to make two set-ups, one 45* left, one 45* right, but all your lines would be done at one time. cary |
| Lathe Bed: how flat is flat enough? | Donkey Hotey | Haas Lathes | 25 | 05-17-2010 02:35 PM |
| 100% flat table for flat bed lamination | Bernhardsen | Printing, Scanners, Vinyl cutting and Plotters | 4 | 08-24-2008 08:31 AM |
| Knurling | gr8life | General Metal Working Machines | 1 | 10-31-2007 05:02 AM |
| Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? | vroemm | Linear and Rotary Motion | 7 | 08-16-2007 12:26 PM |
| Knurling | SPEEDRE | General Metalwork Discussion | 4 | 10-03-2006 06:04 AM |
