I searched on here for a substitute for aluminum for testing programs and found a couple possibilities: Delrin: machines well (though has it's quirks) pretty much the same price as aluminum, if not more Machinable wax: Much cheaper than aluminum, and recyclable, if you are willing to do the extra work. Syrofoam insulation (blueboard): very cheap, messy, and not that accurate. I went to lowes to find something else and came up with Trex. I searched here and there are people talking about it, but not in the context of an aluminum substitute. This is the "Fake wood" for outdoor decks. Its a composite of wood and plastic. It's very dense and machines quite well. Lowes had a 1"x6"x12' plank for $30. The downside is the limited sizes it comes in. http://www.trex.com I'm running a part on it now and it looks very good. Just wanted to share so people searching for aluminum substitute come across this. |
I wonder if that would be "sealable" better than MDF ....MDF bubbles out air for a while when pouring Vinamold on it... And I'm too tight to use Silicone
__________________ Keith |
| It's more plastic than wood and you don't have to seal it. It reminds me of HDPE. It's very sturdy. A lot stronger than MDF. The best part of it is when you route it you don't have to worry about airborne particles like with MDF since it's so heavy. |
I thought that stuff *was* just HPDE? Or some sort of Polyethylene, at least. |
| Here's some links from their site. http://www.trex.com/suppliers/plastic.aspx http://www.trex.com/suppliers/wood.aspx http://www.trex.com/whytrex/whatistrex.aspx |
#10
I am currently using Verdanda decking as the base of my CNC machine, which you WILL be able to see in my build log (signature, below) as soon as I update the dang thing. It is a mix of HDPE and misc wood pieces. It is very strong, won't warp due to weather, but also absorbs things like oil. It will bend if it is kept in the same position for a long time. Good news is that it bends right back. I wouldn't necessarily call it a substitute for Aluminum, but it is very easy to machine, drill, screw, and exhibits strength close to aluminum's. What I would call it is a necessary replacement for MDF. That @$#% sucks so bad. I had a heck of a time trying to do a first build with MDF and I wasted soooo much time with that worthless material. |
| Securing Aluminum to Aluminum | webgeek | General Metalwork Discussion | 3 | 12-29-2009 05:30 AM |
| Bonding aluminum to aluminum - Doable? How? | Arquibaldo | General Metalwork Discussion | 15 | 11-05-2009 09:01 PM |
| Carbide endmills Aluminum vs non-aluminum ??? | zaebis | General Metalwork Discussion | 7 | 09-14-2009 08:53 AM |
| pressing aluminum into an aluminum tube | Fishin_Rod | Mechanical Calculations/Engineering Design | 24 | 07-01-2009 12:23 AM |
| 390 Aluminum | JPMach | General Material Machining Solutions | 3 | 09-13-2006 09:18 PM |
