Old 04-28-2010, 11:48 AM
UKRobotics is on a distinguished road
First Time Milling Steel - Snapped a cutter - HELP!
Today I tried milling a simple part from some 1/4" steel on my recently finished bridgeport interact retrofit. This was the first time I've tried milling anything harder than wood or plastic. I ran the program cutting air first and everything looked fine so I tried again a second time round so it would actually cut something and within a second or two of touching the metal the cutter snapped.
That was the only one I had so decided to call it a day and got some more on order for tomorrow. However even the cheapy end mills are not that cheap so I was hoping to glean some advice from the experts on here to save myself from snapping too many more cutters.
My suspicion is that the breakage was caused either due to a feedrate/spindle speed/cutter size mismatch or due to the way the material was clamped to the machine .. or both. or maybe something else entirely that i didnt even think of.
My setup was with a small piece of 1/4" plate approx 3" x 5" clamped in a vice with about 1/3 of the piece sticking out the side of the vice cause i was cutting from the edge and wanted a bit of clearence from the jaws incase the machine decided to have a funny moment. I'm wondering if maybe even though the vice was done up really tight, that the bit sticking out was enough to cause some deflection which then broke the cutter ?
The cutter itslef was a 0.16" diameter slot drill, spindle speed was 2000 rpm and horisontal feeds were 11ipm. Does this sound about right or was I way off the mark ?
Thinking out loud here, should I have been climb or conventional cutting and if i'd been using the wrong one is that likley to have contributed to the breakage? I'm using a new cam package and I still dont fully understand what i'm doing with it.
Appologies for all the questions and i'm sure I sound like a total noob, but this is a new machine and all my cnc experience up until now has been with softer materials which are a lot more forgiving to the blundering hobbiest. Now trying to cut a bit of mild steel and all of a sudden it seems like I have to be a lot more diligent.
Dom
http://www.ukrobotics.com/projects
Old 04-28-2010, 01:23 PM
kling8 is on a distinguished road
alright with what you wrote, I think your spindle speed is to slow and your feed is to fast. I would conventional mill the part. Are you using a high speed steel cutter or a carbide, if carbide your spindle is for sure to slow. Depending on how you clamped if your part is vibrating that can break the tool. So I think you are on the right track, one thought is to call the tool rep you are ordering the tooling from and ask them for recommended speeds and feeds. Personally I would use carbide maybe around 3500-5000
and feedrate between 10-20, and what is your depth of cut?
Hope this helps good luck
kling8
Old 04-28-2010, 03:10 PM
keebler303 is on a distinguished road
How deep were you cutting? You generally want to use the biggest cutter possible as they are more durable and generally more efficient.
If you are side milling the end of the piece, You could go full depth with maybe .01-.02" cutter engagement. If you are cutting full width, you probably want to use a depth of .01-.02".
Matt
Old 04-28-2010, 06:35 PM
I'll try again tomorrow with higer spindle speed, lower feed rate and the part centred in the vice. Should be able to get away with a slightly larger diameter cutter too.
Dom
Old 04-28-2010, 06:53 PM
Sea_en_see is on a distinguished road
The tool maker should be able to tell you some "starting point" parameters for your cutter. Then based off of your machine, rigidity, RPM, HP, ect. you can make adjustments to the feeds and speeds. I do agree with what has been stated, too little RPM, too high feedrate. Give some more details about the cutter, and your machine.
Old 04-29-2010, 03:26 AM
Machine is a 2.5ton bridgeport series II interact 4 . Tool was a 0.16" 2 flute slot drill
Dom
Old 04-29-2010, 09:34 AM
rowbare is on a distinguished road
Check out Bob Warfields GWizard. I includes an excellent feed and speed calculator.
http://www.cnccookbook.com/CCGWizard.html
a different bob
Old 04-29-2010, 04:55 PM
Thanks for the link.
Tried again today, used a slightly larger slot drill, pushed it further into the collet, jacked up the table so the quil didnt have to come down so far, increased the spindle speed and decreased the feeds. Not so much a methodical approach as try everything at once and hope for the best. Did the trick though. Machined out 4 identical parts and not snapped anything yet.
Dom
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
Weee! first time machining Stainless Steel ImanCarrot General Metalwork Discussion 7 02-08-2008 01:25 PM
milling time (not to be confused with hammer time) barefoot0 G-Code Programing 4 05-02-2007 06:18 PM
Plasma cutter for 3mm mild steel DEEDEE CNC Plasma and Waterjet Machines 5 01-19-2006 05:25 PM
Machining 1020 Steel with Inserted Cutter Machine1 Hard and High Speed Machining 6 01-26-2004 08:26 AM
