Hi all. Newbie here with some questions. I tried a search but came up with nothing. Maybe i'm just doing it wrong... Any how, I had a few questions about how to notch some tubing on my new mill. I have been using a tubing notcher but hope to save some time by having the mill cut it. What I am cutting is 1"X.065 wall 4130 tubing. The tube is offset notched on both sides. One side is notched at 1.5" the other side is 3.5" both are notched so the 1" tube is sitting on top of the others. I hope that makes sense. These tubes are going to be Tig welded together so a super fine finish is not all that important. My questions are: What kind of end mill material should be used? HSS Cobalt or Carbide? Should I use use a finishing bit, roughing bit, or roughing-finish bit? When cutting should I start from the bottom of the tube or the end? Coolant or not? Coated end mills? 3,4 or 6 flutes? I have more questions but will have to post pics in order to better explain. I hope these questions are not ridiculous, I just don't want to buy end mills I wont need. Any help would be appreciated. Lance |
| Also the internal contour on one side will be opposite the internal contour on the other side. I'll post pics as soon as possible. I plan to use this site a ton in the future. I feel best when I can give as well as take. I appreciate any and all help given and hope that through my "stupid" questions many more will not have to ask them. ![]() Lance |
| Need Help!- Swaging and butting 4130 tubing | wilson248 | General Metalwork Discussion | 1 | 02-16-2010 04:10 PM |
| Forming 4130 Streamline Tubing | fatoldman7 | Bending, Forging,Extrusion... | 5 | 02-14-2010 11:24 PM |
| Rough IRON bending, picket twister, scrolling, ring rolling & tube notching tools | FPV_GTp | Metal Working Tooling | 3 | 01-08-2009 06:38 AM |
| Filler Rod for 4130? | Chris64 | Welding, Brazing, Soldering, Sealing | 7 | 09-30-2007 12:01 AM |
| Notching Steel Plate | bb99 | Welding, Brazing, Soldering, Sealing | 3 | 10-13-2005 07:31 PM |
