Old 04-13-2010, 01:46 PM
Molochnik is on a distinguished road
Indexable boring bar in boring head?
This may be a silly question, but I'm curious if there is a reason NOT to use an indexable BB in a boring head on a mill. As I look through a couple of catalogs, I don't see an indexable BB referenced as some kind of optional cutter for boring heads - only as a lathe application.
My boring head takes 3/4" shank cutters, and the cutters that came w/ the "set" are difficult to freshen up w/ hand grinding as there isn't much material to remove before you're well into the brazing and shank body.
I thought this might be a more expedient way to keep a fresh cutter on the boring head. Am I breaking new ground, missing something obvious, or dangerously close to a catastrophy?
Thanks.
Old 04-13-2010, 03:00 PM
I do not see how it can be a problem; having the work stationary and the boring bar moving in a circle is no different at the cutting edge to the way a lathe works.
Old 04-13-2010, 03:58 PM
Well that's pretty much what I was thinking too, but I'm aghast at how much I've learned from this site so far, so I didn't want to discount the prospect that I was missing something.
Thanks for the reply!
Old 04-14-2010, 06:28 PM
Delw is on a distinguished road
I use the 5/8 shank sandviks in the small ccmt series. I have also used solid carbide indexable cutters as well.,
Ive used them long and short. I prefer them to be 3" or less in lenght, mainly because the boring head doesnt hold that much of the boring bar.
one thing that is nice about them is you can cut almost any material with them by just changing and insert.
not to mention you can use different rad. inserts to get a better finish.
also make sure your just a tad below centerline with the boring bar(unlike the lathe), indexables generally don't have as much clearance and the flat( as you are probaly aware by running them on a lathe) doesnt always line up perfectly.
Old 04-14-2010, 08:48 PM
I'm sorry, but I'm not familiar w/ what you mentioned - sandviks / small ccmt series.
Would you elaborate or perhaps provide a link? The swapping of inserts is attractive to me too.
Thanks!
Old 04-14-2010, 09:25 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.sandvik.com/sandvik/0110/...3FOpenDocument
it's fairly standard practice to use insert boring bars with boring heads
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-14-2010, 09:46 PM
heres a kenmetal ccmt boring bar.
Hey Dertsap, Thanks for that link also. I like that series I need to check it out.
Old 04-15-2010, 07:10 AM
Awesome.
Thanks guys!
Old 04-15-2010, 07:36 AM
At the risk of looking like I'm trying to separate the flyspecks from the pepper, is there a reason you favor the CCMT over a 55 degree diamond or even a triangular-shaped insert?
I imagine it may have to do w/ pressure applied.
I just want to be sure I get the right rig; I intend to bore motorcycle jugs w/ this as a primary use.
Boring Head TravisR100 Haas Mills 8 09-20-2009 02:09 PM
D'Andrea boring head, Solid Carbide boring bars etc. morehelium EBAY ADS 1 08-24-2009 11:19 AM
Need Help!- Boring head help!! wrechin2 General Metalwork Discussion 2 03-18-2009 11:51 AM
Boring Head artin51 General Metalwork Discussion 22 07-10-2008 05:12 PM
PSA: MSC's 1/4 carbide indexable boring bar on sale rashid11 General Metal Working Machines 0 07-07-2005 08:05 PM
