Old 04-05-2010, 11:39 AM
mikey74063 is on a distinguished road
I need help with cutting aluminum bar
Hi guys... I am new here and hoping I can get a little advice.
I am wanting to cut 6061 aluminum bar.. my sizes are listed below
3 1/2" x 1/4"
1 x 1/4"
1 x 3/8"
most of thickness of the bar is 1/4"
I am wanting to cut many pieces from 12' bars
I have a new craftsman miter saw and tried with a 10" metal cut off blade that is used with a metal chop saw and I tried using it with cutting 1 x 3/8" and cut it fine but I had to go quite slow..
I need to make many pieces and hoping I can use the miter saw but what blade will work better with 1 x3/8"
Thank you kindly..
Mike
Old 04-05-2010, 12:59 PM
A 'Triple Chip' carbide tooth blade, Freud makes them and it will be marked as suitable for non-ferrous metals.
If you do a custom Google search here on CNCzone, the custom search box is at the top of the CNCzone page, using 'triple chip blade' you will find many thread discussing cutting aluminum with miter saws.
Old 04-05-2010, 01:50 PM
Thank you
Goef.. I do appreciate your help in the right direction.
Need A Quote- RFQ - cutting 1 5/8 aluminum rod jhuebbe Employment Opportunity 3 07-23-2009 09:33 PM
Cutting .250+ Aluminum Drools DIY-CNC Router Table Machines 9 06-04-2009 12:28 PM
3/16 Aluminum cutting zeoncomp General Metalwork Discussion 2 03-14-2008 11:54 AM
Cutting Aluminum darylprice DIY-CNC Router Table Machines 7 07-03-2006 10:51 AM
Cutting aluminum rocks101 DIY-CNC Router Table Machines 5 02-27-2005 01:29 PM
