Old 04-04-2010, 08:33 AM
Aaron 1874 is on a distinguished road
What Type Cutting Tool to Mill SST ?
Hi Everyone !
We are machining alot of Stainless Steel Hydraulic cases 10 x 7 x 15.
We are roughing them out from a billot on a Toyoda and Seiki horizontal cnc mills with 40 taper spindles. Right now they are using 4fl carbide end mills. But the time loss is too much, does anyone have any suggestions for different tooling that can remove alot of metal faster ? THANKS !!!
Old 04-04-2010, 09:02 AM
ironDigit is on a distinguished road
high feeds and appropriate coating and lots of cooling.
high feeds to keep heat in the chip instead of the workpiece.maybe be a three flute or even two for bigger/hotter chips
coatings since the sillicium in stainless wears down your cuttingedges faster then .........
and lots of the cooling again to keep workpiece and cutter at decent temps.
your supplier shoud be able to tell ya wich coating but ..w/hell how would they know ?
just 1cts.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 04-04-2010, 01:45 PM
Delw is on a distinguished road
sandvik kenmetal iscar indexable endmills will get the job done faster. carbide end mills run slow. ofcoarse that depends on how big of an endmill you can run
Old 04-05-2010, 10:59 AM
78nova is on a distinguished road
Talking Milling Stainless
Indexable type tooling may work OK in certain situations but we have had much better tool life and decreased our run times by using A-symmetric solid carbide end mills set out of shrink fit holders.
We like and use Hanita end mills but there are others to choose from.
I can take 3-4 times the depth of cut than an inserted tool will live through.
Old 07-25-2010, 03:00 PM
jamesu229 is on a distinguished road
Check with mitsubishi cutting tools. They have cutters that really move in stainless, will sell on performance PO, and are less expensive in the long run
Looking for cutting tool to mill surface.. Sperstad Want To Buy...Need help! 14 10-21-2008 04:06 AM
Need Help!- need sugestions on type of cutting bit to use ryansuperbee Mini Lathe 3 08-11-2008 09:39 AM
Bed type tool changer gcoding Mechanical Calculations/Engineering Design 1 06-06-2006 07:37 AM
Anyone cutting wax/metal with dremel type spindle? sendkeys General Metalwork Discussion 0 03-29-2006 12:27 AM
Cutting balsa ribs - What type of bit to use landart DIY-CNC Router Table Machines 1 08-09-2004 06:28 PM
