Old 03-30-2010, 07:49 PM
GabyFont is on a distinguished road
Recycling 5C Collets
Hi all,
Is there any company that recycle small diameter 5C collets and rectify it to a larger diameter or something? I'm in charge of a manufacturing area that uses a lot of those collets that ends in the trash after a couple of months. The largest diameter I use is about 5mm so there is plenty to rectify.
Old 03-31-2010, 10:46 AM
CalG is on a distinguished road
Are only the bore sizes worn? Do the outer contact/closing surfaces also need to be renewed? Internal threads for stops etc.
Are the sizes needed in nominal .5 mm increments? That is, if a collet were originally 3mm, do you also use 3.5 mm sizes? The steps could be more or less, but significant material removal adds to the rework time.
Regards
Cal
Old 03-31-2010, 11:39 AM
extanker59's Avatar
extanker59 is on a distinguished road
I think I read in a brochure a while ago that Hardinge reground used guide bushings that you sent them. Maybe they do the same for collets?
Old 03-31-2010, 11:35 PM
Thaks for the replys guys.
Dan, the wear is mostly in the bore size. The increments that I use are a few tenths (.0001).
Ext59, I'll chek their site. Due to our quality policies it is probable that we are not able to re-work them and so I was thinking like someone that bought them to re-sell them.
Scrap metal recycling - American scrap metal recycling Ascrap2003 Want To Buy...Need help! 0 05-05-2008 03:21 PM
Recycling Tooling TMaster General Metalwork Discussion 4 05-22-2007 11:50 AM
recycling metal MBG General Metalwork Discussion 11 09-06-2005 03:27 PM
metal recycling MBG Casting Metals 17 05-17-2005 08:24 PM
