Old 03-26-2010, 04:56 PM
cloverfield333 is on a distinguished road
It is possible to machine a .....
...spoon and/or fork from a solid billet of steel instead of casting the spoon in a mold??? does anyone have any idea on how a spoon or fork could be machined in a CNC Machining Center?
http://visual.merriam-webster.com/im...ware/spoon.jpg
Old 03-26-2010, 05:07 PM
This is another CAD picture of the spoon:
Old 03-26-2010, 05:14 PM
A spoon or fork could be machined on a CNC machining center. However, it would still require additional processing (polishing to remove machining marks etc.) to produce a finished product.
Normally they are punched out of sheet material and then finished by polishing etc. The more polishing etc. will provide more of a perceived quality product. (rounder edges and corners etc.) Far more efficient and less costly.
The pieces can be silver plated to improve their snob appeal. Stainless steel is usually acceptable.
Dick Z
DZASTR
Old 03-26-2010, 05:31 PM
Dick Z
Thanks for your response. Do you have an idea on how to set up the billet so the spoon or fork shape can be machined in a CNC machining center. Would it require an indexing head, or a 5-axis machine???
Old 03-27-2010, 10:31 AM
Machine one side (top or bottom) from a billet. In that first operation machine two accurate registration holes through the billet.
Relocate the billet upside down on a fixture plate with corresponding registration holes or pins (dowels).
Machine second side to completion.
This requires only three axis motion. An indexing fixture would be an improvement but not needed. Four or five axis of controlled motion would produce nearer to finished workpiece but each added axis requires a more expensive and complicated machine and programming support system.
It's the old adage, "Speed costs money, how fast do you want to go?" Is this an exercise to prove it can be done or a "real world" production question. In the real world, you must justify the economics of the method.
Hope that helps.
Dick Z
DZASTR
Old 03-27-2010, 02:08 PM
juergenwt is on a distinguished road
OK - not a spoon, but some awful CNC programming and machining. Site is in German but clk. on the underlined head lines for some great CNC movies.
Clk here: http://www.emuge.de/deutsch/medien/videos.html
Ps. You can clk on the UK flag upper right hand corner for English.
Have fun!
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Another machine rigid tapping (stepper machine) samco LinuxCNC (formerly EMC2) 10 04-10-2009 07:21 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
