| Hello Everyone, I have to thread mill some 2"-11-1/2 and 3"-8 NPT holes in aluminum. I've never thread milled NPT holes before to say nothing of holes this big. Should I prepare the holes with a tapered mill before thread milling them? If so, can I use a tapered mill with a 1-1/2 degree taper per side and let the thread mill put in the 1.79 degree per side taper or do I need a 1.79 degree per side taper mill? Thanks in advance for any help you can give! T |
| Thrd milling is different than tapping. The only reason you ream to a taper hole for tapping is to take it easy on the tap. The thrd mill will mill its own taper as long as your programmed right. I've done lots that big. Even 4140ht. Straight bore ,no problem especially aluminum. |
| Tags |
| npt, thread mill |
| Lathe offset hole thread mill without y-axis | jabingb | General Metalwork Discussion | 2 | 07-18-2009 04:25 PM |
| Suggestions on milling large hole | metalworkz | Dolphin CADCAM | 4 | 05-03-2008 11:46 PM |
| Npt thread milling pre hole sizes | magneto259 | General Metalwork Discussion | 2 | 04-12-2007 06:33 AM |
| Preparing for me Super X3 arrival, some Qs | rashid11 | Benchtop Machines | 2 | 01-14-2007 09:23 PM |
| Thread milling cutterdia / hole ratio | HuFlungDung | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 12-31-2003 08:44 PM |
