Results 1 to 2 of 2
Thread: I am having problems with my Mazak AJV-18n
    Mar 2010
    North America
    Post I am having problems with my Mazak AJV-18n
    I have been using this machine for a while and now the tool changer just stopped working. The changing post wont drop down and spin around like it should. It just stays up and a code comes up with "300 ATC ARM CW SENSOR MALF". I have no idea what that means. Please help.
    Registered cncnitro's Avatar
    Sep 2008
    j bird,
    It sounds like your tool change arm has drifted off its switch. My machine does this from time to time.
    You need to locate the solenoid switches(ajv60/120 on back of machine near tool changer arm,under sheet metal cover) that operate the arm. Using an allen wrench,depress the solenoid switch on one side, if no action, depress opposite side.This will force the arm back onto its switch. Clear alarm on control panel and you should be ready to run. you may also need to up the air pressure, be careful small adjustments to air screw mean large increases in tool arm speed.
    Good luck!
  1. Need Help!- Mazak 1550 Post Problems
    By o Lee o in forum EdgeCam
    Last Post: 03-06-2010, 04:59 AM
  2. Anyone have Problems dealing with Mazak?
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2009, 11:10 AM
  3. Mazak M4 Problems
    By Monomer in forum General Metal Working Machines
    Last Post: 05-30-2008, 11:09 AM
  4. 6MB Problems (Mazak Microcenter V)
    By ma85562 in forum Fanuc
    Last Post: 04-17-2007, 02:32 PM
  5. Mazak Vmc Yaxis Problems
    By barebonzchop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2006, 09:01 AM
