Having tough time. Turning a part out of 17-4ph. Insert life not very good. Its a 1." dia. stock only turning to .7865 leaving stock for grind. I have tried various speeds and feeds but only seem to get 40 to 50 parts per corner. Gone from 275sfm to 875sfm tool life didint seem to change much. Any ideas out there sure could use some help if you think should be getting better tool life. |
| Thanks Max. What kind of tool life do you get. I am using Iscar cnmg-432 TF IC807. I have alot of these parts to run and think the boss would rather I use a few more corners on insert than run that slow. Im sure it would improve tool life but it would take me forever to run. Thanks I may try just to see how many more parts I would get per corner. |
| I'm hanging out 3 5/8 rough and finish end of part which has .125 radius on end that goes into 30 deg. angle which I run a little past the 1 inch stock then make one rough pass on o.d. then finish turn to .7865 then partoff. I went down to 235sfm but didnt get any better tool life. I'm running at 675sfm with good flood coolant, guess I'm happy with the 50 to 60 pcs. per corner. Was just wondering if it could be better. Thanks for your help Max. |
| Walter grade WSM20, run at 850sfm (260m/m) in 17-4. Life measured as time-in-cut is 45 to 50 minutes per edge. Let me know what your depth of cut and desired surface finish is, and I can suggest a chipbreaker and feedrate to use. |
| Turning 17-4 | shep640 | Mini Lathe | 0 | 04-07-2009 04:50 PM |
| Need A Quote- 304 SS Turning Job | JMFabrications | Employment Opportunity | 3 | 11-07-2008 10:01 AM |
| Turning Cam | Regnar | General CAM Discussion | 2 | 04-29-2008 04:27 PM |
| Turning | camtd | SolidCam | 1 | 08-01-2007 12:40 PM |
| Turning S7 vs. D2 | wildcat | General Metalwork Discussion | 1 | 07-06-2007 09:06 AM |
