Old 03-22-2010, 07:00 PM
parkson is on a distinguished road
Machining Maskant
I have a job where I need to machine pre finished (mirror) parts. The chips from milling can scratch the face. I need to mask the parts w/ some liquid masking that won't tear against the forces of the endmills and not be eaten up by the coolant.
I have looked into the following.
1. Dymax UV resin (to expensive)
2. Tolber (xp-2000 and mircoshield) both tear during machining.
Also the masking must be removed via peeling or light heat (150deg max)
We cannot use solvent to remove.
Any ideas?
-Park
Old 03-22-2010, 08:33 PM
ctate2000 is on a distinguished road
Could you use parafin? I have never done this but it sounds like a good idea?????????????
Old 03-23-2010, 02:25 AM
Delw is on a distinguished road
The stuff they use on regrind endmills to protect them. Its like a wax , I dont remember the name.
we used it on big aluminum parts that were polished and also on parts that had to be machined that are very thin to eliminate chatter,
Old 03-23-2010, 09:39 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I make a lot of lenses and mirror and use Spraylat
http://www.spraylat.co.uk/industry_detail.php?id=2
You brush it on or paint it on. When you're done stick a bit of tape to it and just peel it off.
I've also used Opticlean, it's more expensive but cleans the surface good when it's peeled off.
I love deadlines- I like the whooshing sound they make as they fly by.
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
CNC machining RFQ rubberdown Employment Opportunity 14 08-23-2007 11:15 AM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
New to Machining, need help johan_tr2000 Mechanical Calculations/Engineering Design 4 10-27-2005 09:06 PM
cnc machining fastolds Employment Opportunity 0 03-29-2005 02:37 AM
