| I am reverse engineering a draw tube adapter for my collet chuck that has an internal metric thread that has a Ø58mm minor dia with a 2.0mm pitch. I looked in the machinist handbook and did not see anything that fits those domensions. I figure that if I knew the thd depth for the pitch I could use that to get me close. I googled "metric thread depth" and found a site that showed a metric thread depth spec 0.614 x pitch. On the same site they show a table with Thread size, pitch, tap drill size. I found a Ø58mm drill size with a 2.0 pitch and a thread size Ø60mm. That would be a depth of 1.0mm but if you multiply .614 x 2.0 it equals 1.228. What am I missing? I would use the draw bar for a gage but that is attached to the 3 jaw chuck that I am using to machine the part. Any ideas? |
| You are looking at the tap drill size - as Bent said : Nominal size minus pitch. This goes for metric threads and 60 deg. inch threads also. the full theoretical depth "H" is given as 0.866xP. This is from a (theoretical) sharp point on top and bottom of the 60 deg. . 0.614xP (h3) is from the radius (R=0.144P) at the bottom of the EXTERNAL thread to the top (nominal size). More info here: http://www.engineersedge.com/hardwar...ead-sizes1.htm and here: http://www.gewinde-normen.de/en/iso-coarse-thread.html |
| Metric thread repair - TL2? | flick | Haas Lathes | 4 | 03-09-2010 03:52 PM |
| Metric thread cutting? | machinist360 | General Metalwork Discussion | 3 | 03-09-2010 03:28 PM |
| metric thread | riverracer | Haas Visual Quick Code | 3 | 03-09-2010 03:01 PM |
| Metric Thread On LM8x14 | pzzamakr1980 | Mini Lathe | 6 | 06-04-2008 08:02 AM |
| metric thread cutting | toolmaker_79 | G-Code Programing | 3 | 09-03-2007 06:11 AM |
