Hi Group I am working on a spindle design for metal machining. I was wondering what the high and low spindle rpms would be required for general machining. I`ve seen the Bridgeport specs at 0 to 4500 rpms. The high end at 4500 seems high for metal when is this higher speed required. I will be using a PMDC motor to drive the spindle. I need to know if I need to gear up or down for maxium usage. The PMDC motors are avalable in 1725 or 2500 rpms. Thanks |
When you use carbide tools. When you cut aluminum. With a small diameter carbide cutter in aluminum you might want 45000 rpm! A good place to ask is where you buy your tools, they can tell you what the best speed and feed is for the cutter and the kind of work you do. |
| you're going to need to know the theory on this, but the good news is its simple. Then, knowing to what use you will put the machine, you can figure out the speeds you need. check out http://its.foxvalleytech.com/MachSho...c/SpeedRPM.htm the big BUT here is those are optimal numbers and our older or lighter duty home shop stuff usually taps out on rigidity and hp before we achieve those speeds. On my XLO (b-port), I rarely get over 3k but there’s been many times when i wanted less than 100. |
| Sherline spindle to 30k RPM -- am I crazy? | nicad | General Metal Working Machines | 21 | 11-17-2010 02:57 PM |
| Spindle speeds for PCB milling | CactusChip | General Metal Working Machines | 15 | 04-20-2007 03:54 PM |
| Attn: Haas Techs/TL-1 SPINDLE SPEEDS | DEAN | Haas Mills | 1 | 07-23-2005 01:07 AM |
| Spindle speeds and feedrate cap | HuFlungDung | OneCNC | 11 | 07-05-2005 12:05 PM |
| Gilman box spindle pics | Swede | Benchtop Machines | 5 | 03-30-2005 09:41 AM |
