Old 03-02-2010, 10:51 AM
rylanrouge is on a distinguished road
RPM troubles...
We have an Okuma Lathe and we switched the machine to run programs in Metric. When running a part (8" dia.), I set the max speed with
G50S800... then G96S600... The part is spinning much faster and burning up tools, it's not recognizing the G96. It seems as though the machine is reading the speeds (RPM) in Metric. Is there some type of conversion table or some number I sould divide the 600 by? Any suggestions???
Old 03-02-2010, 12:44 PM
sambo67 is on a distinguished road
DO YOU HAVE , I THINK THE CODE IS G50 AT THE BEGINNING OF YOUR PROGRAM WHICH SETS YOUR RPM LIMITS
VMC1000 Troubles Kiser Bridgeport and Hardinge Mills 2 07-06-2009 10:01 PM
Motor Troubles tmd019 Hobbycnc (Products) 2 04-11-2007 08:34 AM
air troubles wadetool Haas Mills 2 02-19-2007 03:30 PM
DXF troubles kung G-Code Programing 2 11-02-2005 03:41 PM
CAD Troubles Blackhawk General CAM Discussion 27 06-11-2005 10:13 PM
