Old 02-25-2010, 10:05 PM
nfrees114 is on a distinguished road
Speeds and Feeds for ASTM A-500 Grade B Steel
Hey all- So I machine 99% aluminum. I recently have been machining some structural tubing. I am just curious if anyone knows what you would look up for speeds and feeds in the machinist handbook for this grade of steel? i seem to be wearing out tools like crazy. i used the #'s for a 1018 steel and am not sure if it's even close to correct. the problem is there is no catagory in the machinist handbook for A-500. i was just curious if anyone does a lot of this type of machining and can throw out some speeds and feeds. or what is comparable to look up in the machinist handbook that i can use. Thanks!
Nate
I mainly just use a 4 flute Iscar solid carbide end mill. for most operations.
Need Help!- Engraving Grade 50 Sheet Steel racecraft General Metalwork Discussion 16 01-22-2010 04:36 PM
What is the best grade Stainless Steel for eating utensils??? brianklein General Metalwork Discussion 6 10-17-2009 11:08 PM
turning 430F grade stainless steel callganesh General Metalwork Discussion 2 11-03-2008 03:25 PM
Help! with Feeds and speeds please! sjotime! Visual Mill 3 02-13-2008 12:56 AM
feeds and speeds porkchop21 Bridgeport and Hardinge Mills 2 08-30-2007 07:52 PM
