Old 04-18-2005, 11:43 PM
zorgzorgzorg is on a distinguished road
Is this servo motor strong enough?
Is this servo motor strong enough to convert a bridgeport type mill into a CNC machine? they are DC brush type MCG make model # ID33 004.
MOTOR SPECS.
TOT. VALUE UNITS
Max. Operating Speed (Snl) MAX 3700 R.P.M.
Continuous Torque (Tc) MAX 225 OZ-IN
Peak Torque (Tp) MAX 1125 OZ-IN
Torque Sensitivity (Kt) +/- 10% 32.19 OZ-IN / AMP
Back Emf Constant (Ke) +/- 10% 23.8 V / K R.P.M.
Terminal Voltage (Vi) MAX 90 VDC
Terminal Resistance (Rt) +/- 15% 1.14 OHMS
Inductance (L) +/- 15% 3.51 mH
Rotor Inertia (Ja) NOM 0.063 OZ-IN-SEC squared
Friction torque (Tf) NOM 8 OZ-IN
Damping Torque (Td) NOM 1.4 OZ-IN / KRPM
Winding Temperature MAX Celsius 155
Weight NOM 10.5 LBS
MILL SPECS.
Table size 230 x 1244mm
Quill travel/diameter 127mm/86mm
Table travel 800mm
Spindle to table (max.) 515mm
Cross travel 320mm
Been Priced at $215.50 USD each
If no, what servo motors are recommended?
If yes, what servo controller drives are recommended?
Thinking of using 5mm pitch ball screws.
What pulley ratio should I use?
Thanks in advance
Old 04-19-2005, 07:44 AM
Gold Member
lerman is on a distinguished road
See:
Seeking Advise - new project
For a similar question and my answer.
The motors you are asking about are less powerful and more expensive than the ones mentioned in that thread.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Small servo systems and power supply imserv Product Announcements & Manufacturer News 4 04-03-2008 12:11 PM
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 09:05 AM
Servo Motor Running away. murphy625 CamSoft Products 38 02-27-2005 02:08 PM
Mixing servo and stepper ty1295 Servo Motors and Drives 0 01-19-2005 10:26 AM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 03:56 PM
