Old 02-16-2010, 04:21 AM
d_chappell is on a distinguished road
What type of motor for a lathe?
Hi, I'm looking into building a CNC lathe from scratch and need some advice about what motors to use for the actual turning of the workpiece.
I'm using steppers for the XYZ axes, but I would also like the motor that turns the workpiece to be direction and speed controllable. Would stepper motors be up to the job of turning a lathe chuck? My suspicions are that they wouldn't. What would people suggest?
Dave
Old 02-16-2010, 05:28 AM
kawazuki is on a distinguished road
First choice 3 phase AC - power and control, instant reverse? but won't index as well? then maybe a really big Servo motor - will have the control but not the spindle hp or then a biggish Brushless DC motor - Hp but maybe not the same control?
All depends on what work capacity and tooling requirements you require IMO
Old 02-16-2010, 07:39 AM
Hi, thank you so much for your response.
My initial thoughts are that the machine will be able to handle up to softer metals such as aluminium and brass. The frame of the machine I want to be constructed out of aluminium profiling, so working on harder metals would be out of the question.
I assume this will determine what hp and rpm I will require in the motor. Do you think something like a 3/4 hp, 1400rpm motor would do the trick?
The machine will be a swiss style lathe which I am able to stop, reverse and position the workpiece as i wish, so control is quite important. From your advice it seems that a servo would be the route to go down?
Old 02-16-2010, 10:25 AM
I'm really no expert machinist but the motor performance you are suggesting sounds appropriate for plastic, brass and ali turning but i'd be more concerned over using aluminium profile frame! First rule of turning seems to be mass/weight/rigidity and lots of it - ali doesn't have much.........although the Sherline series lathes seem to work well enough?
Old 02-16-2010, 01:03 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Why do you want to be able to control the main spindle in Step direction mode?
If you will only be using this as a lathe, put 3 ph motor and VFD on it.
If you build it as a live tooling lathe with mill capablity, use a big servo, and servo drive.
Buiding out of aluminium profile sound like a poor choice.
Why not buy an offcut of granite from a local grave stone maker, and mount linear rails?
Regards,
Mark
www.wrathall.com
Old 02-17-2010, 06:55 AM
My intention is to be able to carry out milling operations as well as lathe work. That way I hope to be able to carry out operations similar to what you see at around 0:46 sec on this video;
http://www . youtube . com/watch?v=fW_e7LuuGWs
I had a feeling that the aluminium idea might be an issue. There were a number of reasons why I entertained the idea; one was cost and ease of construction, the other was that I have a vague idea of making the machine compatible with this project. If you can imagine one of the cubes that they describe there with a lathe inside, then that is kind of what I was getting at.
Do you know if there are any places that sell steel profiles of the same design as the aluminium ones that are widely available? That might be a solution - albeit a very heavy one (though it seems weight is a positive attribute in this instance).
I've never used the Sherlines myself. if anyone has experience of them then feedback would be welcome. From what I understand, the earlier ones had brass beds and cast bases with some aluminium parts around the place - I don't know the details exactly
Regards
Dave
Need Help!- What type of Hardinge lathe is this??? Beezer Hardinge Lathes 4 02-13-2009 04:10 PM
type of motor for A axis - Lathe operation plus indexing? mcArch Plasma, EDM and other similar machine Project Log 0 01-10-2009 07:59 PM
Motor Sanyo type 103-820-2 chockstef Spanish CNCzone 0 03-29-2007 04:46 PM
Motor type and sizing help AcuBill Stepper Motors and Drives 1 10-12-2005 11:13 AM
what type of stepper motor to use landart DIY-CNC Router Table Machines 0 08-26-2003 10:48 PM
