Old 02-15-2010, 06:33 PM
aucran is on a distinguished road
Rubber mat to reduce vibrations.
I'm building a wood stand for my ZAY045FG (IH) mill, would mounting the mill on a rubber mat help reduce vibrations as far as noise concerned? Or is all the noise is just coming from the motor and cutter, and I just have to live with it?
(I mean adding a rubber mat to the table the mill is mounted on, so the mounting bolt holes would go through the mat.)
Thank you!
Old 02-15-2010, 09:11 PM
CalG is on a distinguished road
Bolting through a rubber mat won't do much to quiet a machine. The bolt still transfersthe vibrations.
A cheap way to try is to cut up a discarded automobile tire.
Sharp knife and a fine tooth hack saw to cut any metal chord.
Drilling a hole in rubber can be a pain.
Good luck
Old 02-16-2010, 11:26 AM
Try to "google" Unisorb. They have a lot of possible solutions.
Dick Z
DZASTR
Old 02-19-2010, 11:48 AM
will gilmore is on a distinguished road
You need to put the isolating material on both sides.
Bolt head
Washer
Machine
Rubber
Table
Rubber
Washer
Nut
Vibrations in the Z axis mrscheider Taig Mills & Lathes 3 04-29-2009 07:32 PM
table vibrations/ head vibrations how to adjust chaz6966 Cincinnati CNC 1 02-25-2009 08:42 PM
Vibrations when turning? rka Haas Lathes 11 08-06-2008 07:36 AM
eliminating vibrations turpija Mechanical Calculations/Engineering Design 101 10-23-2007 10:56 PM
Sponge Rubber and Diamond plate looking rubber? DennisCNC CNCzone Club House 1 06-01-2007 12:15 PM
