Old 02-11-2010, 04:41 PM
ukpete is on a distinguished road
Chatter on duraluminiun
I'm beginning to get the hang of cnc machining in ally - haven't welded an end mill to the workpiece for days! - but I'm still getting some chatter.
I'm cutting 1mm into duraluminium with a 2mm carbide high helix single flute bit. Spindle is running at 18,000 and feed rate is .5 m/min. I'm taking .2mm depth cuts each pass (ok, I'm a coward after breaking too many expensive bits) and using air and a coolant recommended by the tool suppliers. I'm rubbish at doing the maths to determine the cutting parameters, and everyone seems to have a different view. Machine is substantial with a 4' x 8' bed weighing close on a ton.
Any thoughts?
Thanks,
Peter
Old 02-11-2010, 06:52 PM
universalfab is on a distinguished road
Somewhere there is a bow in your material. How big of piece of material are you cutting? You need to find a way to clamp your material down better.
Newbie- help with x2 chatter, Micro Milling Benchtop Machines 2 01-24-2010 11:53 PM
Chatter? vectorsc Mazak, Mitsubishi, Mazatrol 5 12-07-2009 08:39 AM
Need Help!- Chatter TravisR100 Haas Mills 16 10-24-2009 05:08 PM
Problem- chatter Claude Boudreau DIY-CNC Router Table Machines 2 05-23-2009 11:18 PM
Chatter gabeless Hard and High Speed Machining 10 07-14-2005 11:09 AM
