Old 02-11-2010, 11:29 AM
ligito is on a distinguished road
Mill feed direction
When using a vertical mill, should the direction of cut always be from left to right?
I have broken a few end mills and my 3/4 just lost a tooth.
I wonder if backing it to the left might have been the cause.
Old 02-11-2010, 01:31 PM
BillTodd is on a distinguished road
If you machine has even the smallest amount of backlash, it is very important to feed towards the cutting edge against the direction of cut (whichever direction that may be). If you feed in the same direction as the tool is cutting, the tool can grab the work piece and pull the table into the cut thus taking a greater bite than it should, chipping the tool as you describe.
If the backlash is very bad, the result can be a shattered tool and an injured machinist - so be careful
Bill
Old 02-12-2010, 02:23 PM
juergenwt is on a distinguished road
Ligito - It is called "climb milling" and for a standard vertical mill it should only be done by an experienced operator. Some times you have no choice and you have to climb mill. Other times it can be an advantage when removing a large amount of material. Make sure your cutter is more than 1/2 of the dia into the material, snug up your gib screw and be very careful at the end of the cut. Like I said - unless you are experienced - stay away from it.
Okuma mill feed rate jumps to rapid feed easyguy97 Okuma 6 12-20-2009 04:14 AM
Need Help!- Entire headstock of mill deflecting when cutting -X direction? Bowman Benchtop Machines 19 03-05-2009 09:55 AM
Small mill feed? StormForge General Metalwork Discussion 3 06-14-2008 02:03 AM
help with speed and feed carbide end mill alex 850 Bridgeport and Hardinge Mills 9 12-26-2007 11:10 PM
End Mill direction... CW or CCW? ngr1 General Metalwork Discussion 10 01-27-2005 09:42 PM
