Old 02-10-2010, 06:35 PM
CVMichael is on a distinguished road
Spindle for cutting metal ?
I finished my homemade CNC, all I need is a spindle / router.
I want to be able to cut metal, and I need a spindle powerfull enough, but at 110V. Here in North America everything is 110V....
I cannot find a spindle at 110V, and the routers that I found at 110V have too many RPM (i.e. for wood working), usually from 8,000 RPM to 25,000 RPM. I want something that can go as low as 200-300 RPM.
Can someone give me some suggestions please ?
Thank You
Old 02-11-2010, 04:56 AM
bearwen is on a distinguished road
Well you could use just the spindle assy from a small table top mill like an X2 I think little machine shop sells them. Honestlly I dont know what you have built I sure hope it is VERY VERY rigid if you built something like the wood router guys have I will tell you it probablly wont be rigid enough to be super accurate so use a wood router and just watch the depth of cut. If you go and look at the speed and feed for a mill and you use small diameter tools that are carbid tipped then you will see that the spindle speeds can be very high. example a .25" tool cutting in plain carbon steel @ 140 fpm cut speed (cut speed FPM is not the same as IPM on your cnc) is 2139 rpm spindle speed ( I believe that is for HSS tool carbid FPM is usually 3 times higher so it would be 6417 rpm)
Old 02-11-2010, 09:03 PM
rowbare is on a distinguished road
Perhaps something like a Taig or Sherline spindle would work.
http://www.sherlineipd.com/spindles.htm
http://www.cartertools.com/parts.html see p/n 200-60 ER16 headstock.
bob
Old 02-12-2010, 10:15 PM
will gilmore is on a distinguished road
I'm guessing that you can find 240VAC in your house/shop.
here is a 120VAC option: http://littlemachineshop.com/product...ory=-269978449
Old 02-14-2010, 10:34 AM
bagherdn is on a distinguished road
finished spindle
i've finished my new spindle for my cnc( the latest part first made!)
main part is high precission straight shank er16 collet as you can see:
cutting thin metal clittle Opensource Forum Rules 3 09-05-2007 04:27 PM
Anyone cutting wax/metal with dremel type spindle? sendkeys General Metalwork Discussion 0 03-29-2006 12:27 AM
How to choose Spindle for Metal cutting CNC Mill ? Calico General Metalwork Discussion 2 07-05-2005 08:21 PM
Cutting metal signIT DIY-CNC Router Table Machines 2 02-19-2005 11:14 PM
Q for metal cutting with table saw cnc2k General Metalwork Discussion 7 02-09-2005 06:41 PM
