Old 02-09-2010, 07:26 AM
Anilisn is on a distinguished road
Selection of milling method
Hi all,
I'm planning to make a mold by micromachining. I tried using a CAM software to generate NC codes for the roughing operation, and it seems that there are a few possible ways to do it. Either by zig zag method or the follow periphery/contour method. Does anyone know the benefits of using either one?
Thanks.
Old 02-09-2010, 07:51 AM
brunog is on a distinguished road
Typically the zig zag method is used when using a facemill to get an even flat surface. Periphery/contour method is what you want to use to mill pockets and contour as the mill is cuting all the wall or edges in the same direction and gives an even finish in general.
Best regards
Bruno
Old 02-09-2010, 09:31 AM
Best regards
Bruno
Thanks Bruno!
My mold design is a positive feature in the center of the workpiece. From the CAM software, both methods can be used to get the desired shape. In that case, will the zigzag method be better?
Best method for Dry Run tmachine Fadal 11 05-23-2008 09:01 AM
Har milling machine Selection Adhiland Hard and High Speed Machining 0 11-05-2007 09:23 AM
What method will be more accurate? DennisCNC Mechanical Calculations/Engineering Design 9 09-01-2006 05:44 PM
Best method to make this Moondog General Metal Working Machines 14 10-07-2004 05:49 AM
Best Method musky2much WoodWorking 1 10-13-2003 08:59 AM
