Old 02-06-2010, 10:12 PM
ubaldc is on a distinguished road
removing shaft on 8x12 hf lathe
in case anyone is interested, i pulled the shaft out of the 8x12 lathe without any problem. loosen the lock nuts on the back of the shaft, take off the pulley and gear and tap out the shaft with a plastic hammer. the pulley and gear slid right off. there are tapered roller bearings on the shaft.
make sure when you assemble it, tighten up up the nut until the lathe runs quietly.
send me a note if anyone has any questions.
chris
Tags
8x12, removal, shaft
Need Help!- adapter plate for 8x12 hf lathe ubaldc General Metal Working Machines 2 01-29-2010 02:03 PM
Removing (changing) the chuck on HF 8x12 cknowlto Mini Lathe 5 11-03-2009 01:45 PM
Removing R8 key from X3 Spindle shaft stag53 Benchtop Machines 7 04-23-2009 07:46 AM
8X12 HF Lathe CNC conversion? Noto Mini Lathe 1 10-22-2008 08:23 AM
DIY QTC for HF 8X12" Lathe?? scubasteve_911 Mini Lathe 20 02-05-2008 05:44 PM
