Old 02-05-2010, 01:38 PM
aucran is on a distinguished road
Random question about Face Mill angle
I saw this add on Shars Tooling Website: http://www.shars.com/.
http://www.shars.com/products/view/7...ll_SEHT_Insert
It made me wonder why a 45* set angle for cutters would have increased feed rates over a 90* set angle. Seems like it should be the same.
Sorry, random question. >.<
Anyone know though?
Old 02-05-2010, 02:38 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Face Mill Approach Angle
A 45deg approach exerts less radial pressure on the workpiece than a 90deg approach, so you will find you can plough through quicker without as much shrieking (from the cutter that is).
It does, however, exert more axial pressure, so make sure the workpiece is secure!
Have just started having some experience with Feed Mills. The very shallow lead angle means you can feed at about 1mm to 1.5mm per tooth per per rev. Downsides are you can only cut about 1mm to 1.5mm deep (and you don't get much warning of your cutter about to explode). They seem to work best when fully-engaged, eg helical milling.
DP
Last edited by christinandavid; 02-06-2010 at 10:24 PM. Reason: Feed Mills Comment
Old 02-06-2010, 07:13 PM
rowbare is on a distinguished road
Check out http://www.cnccookbook.com/CCBlogOct2009.htm see the section called Sturz Milling and Other High Tech Milling Tricks"
Tags
face mill
R8 face Mill Question! QSPSB Benchtop Machines 14 12-22-2009 12:42 AM
Where to find Shell mill / Face mill arbor for taig 725franky Taig Mills & Lathes 5 11-18-2009 04:48 PM
Face Mill Insert Question ImanCarrot General Metal Working Machines 1 06-04-2008 10:00 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 07:56 PM
