Old 02-05-2010, 01:21 PM
ka67_72 is on a distinguished road
Phase Converter for Matsuura
I just bought a '93 Matsuura MC-600 vf with a Tsudakoma rotary tilt table and Yasnac I80m controller. It has a 10hp spindle. Once it figure out how to get it through my garage door, I'm going to need to power it. I have a home made converter that I kick start for my series one BP, but I'm going to have to step up for this. What do I need to look for in a phase converter for this? Do I need a "CNC" phase converter or will a regular rotary work?
Thanks,
Kevin
Old 02-05-2010, 07:22 PM
Kool Parts's Avatar
Kool Parts is on a distinguished road
The last one I did I bought the parts from this outfit. They also have a web site if you are like me and don't buy through fleabay.
They also sell turn key units..all of their stuff is first class, and when you call tech you actually get some one that knows what they are talking about.
As far as "cnc" converters go its all about balancing with capacitors so the legs are close. Mine ended up at 4%.
Just don't try to save that last dime and go with a good company and you will be fine.
Gary
American Rotary
Old 02-05-2010, 08:59 PM
I was looking at their stuff earlier today. I had thought about building a converter, but I spent what is a lot of money, for me, on this machine and I want it to be right. I was thinking of buying one of the 30hp controllers and finding my own idler. It looks like most idlers have had the shafts cut off. I can find a used motor cheap and was thinking of having it serve double duty occasionally driving a roots pump for a flow bench.
Thanks,
Kevin
Old 02-06-2010, 06:37 AM
Kool Parts's Avatar
True they do that for "safety"
You can also build a bracket that holds a small motor with a pulley..say 1/4 hp..and use a v belt over the end of the shaft sticking out of your idler motor. That way you can just swing the 1/4hp up to tighten the belt and get your idler up and running. Then when you energize the idler it takes a Lot less start up current.
Its easy to build a cage that sits over the end so it would still be safe.
Gary
wtb: 20 or 30 hp phase perfect phase converter gaugemate Want To Buy...Need help! 0 10-23-2008 12:06 PM
DIY 3 phase converter blackbeard52 Phase Converters and VFD 2 01-16-2008 09:46 PM
phase converter contractdesign Bridgeport and Hardinge Mills 8 05-30-2007 03:39 PM
DIY phase converter? wyobmf Phase Converters and VFD 9 07-26-2006 04:37 PM
RF from phase converter ? DieGuy Phase Converters and VFD 1 10-20-2005 07:14 AM
