Old 02-02-2010, 07:03 AM
buggsson is on a distinguished road
Boley BC 32 lathe, encoder problem
We have a Boley BC 32 CNC-lathe that we experiences a problem with. The encoder ring, used to control the C-axle position of the main spindle is loose. It is placed in a very tight position and we need to find a way to fasten it again without having to dismantle the whole mechanism. There is two locking screws that needs re-tightening, but they are very hard to get at. We approach the problem from behind the machine through a small hatch, but then the transducer is in the way in accessing the screws.
My guess would be that replacing that transducer, after having removed it would be kind of hard? There shurely would be some alignment issues?
Any suggestions would be highly welcome.
I totally forgot mention the part number of the encoder ring, which is C115 and the locking bolts are C115a.
Need Help!- DMC 70V Encoder problem leike Deckel, Maho, Aciera, Abene Mills 12 03-23-2010 08:05 PM
Bridgeport 760 t16 encoder problem jke6113 Bridgeport and Hardinge Mills 1 09-28-2008 07:36 PM
Encoder problem? paulend Servo Motors and Drives 5 02-06-2007 09:01 AM
Encoder problem? pauls Industrial Hobbies (Support forum) 11 12-16-2006 06:51 PM
lathe wont rapid above 25% encoder problem????? imwllc General Metal Working Machines 2 08-01-2005 07:54 AM
