Old 01-31-2010, 01:06 PM
pelesl is on a distinguished road
Question about small parts on the lathe
Basic question about turning a part:
I am making a small part that has a 3/16" diameter that steps down to 1/16" diameter. The 1/16" part is about 3/8" long.
I have tried a couple of times now and I end up with a taper on the 1/16" section. At the "free" end, it's about 3 or 4 thousands larger in diameter than at the "connected" end. I know this is due to improper technique/bad tools. I've tried a couple of things, including making sure my tool height was dead on center---that improved things a bit. The cutter I'm using is the type with inserts, and the insert is relatively new. Material is 303. The lathe is running at 1200 RPM.
So how do you machine straight on a lathe on such a small diameter if you can't put a live center on the free end?
Old 01-31-2010, 06:56 PM
Dennis Rech is on a distinguished road
I would start with a 3/16" rod that is 1/4 inch too long.
I would support the right end with a dead center and machine the 1/16" portion to size and then cut off the excess 3/16" portion.
Old 01-31-2010, 10:27 PM
will gilmore is on a distinguished road
The taper is caused by the free end deflecting away from the tool. Aside from supporting the free end (above is a good idea) having an extra sharp tool (lots of rake) and taking light passes will help.
Old 01-31-2010, 10:48 PM
Machining 303 that diameter, that length and only getting a 4 thou taper is good; there is nothing wrong with your technique.
It is possible you could improve it by using a very sharply ground HSS tool, carbides do not have a really razor sharp cutting edge and they always exert more force on the workpiece than a really sharp HSS tool.
Old 02-01-2010, 07:08 AM
kentucky jeremy is on a distinguished road
add in an x movement at the connected end of your prog. and tell it to feed up then offset tool down to reach size disired
Pneumatic parts catcher moving too jerky: small parts can shake out MadMax Daewoo/Doosan 4 12-14-2009 05:13 PM
Need A Quote- 2 small 6061-t6 HEX bar parts. LATHE only aaron p Employment Opportunity 10 04-20-2009 11:34 PM
Haas OL-1 desktop lathe for small parts ? Metalmog Haas Mills 9 11-23-2008 01:19 AM
Need A Quote- Resubmitted RFQ - Small Delrin parts suitable for cnc lathe rodjava Employment Opportunity 2 03-10-2008 10:24 PM
small parts question inpro Machine Created Art 3 10-27-2006 08:09 PM
