Old 01-30-2010, 10:31 AM
dpaish is on a distinguished road
Milling Machine and Surface Grinding
I have a small cnc mill and wondering if it is possible to surface grind small (1.5" wide, 0.125" thick and 8" long) stainless stock? Please advise.
DP
Old 02-01-2010, 06:06 PM
wfung is on a distinguished road
I am curious about this as well. Would it be feasible to mount an arbor in the vertical spindle to accept a grinding stone, and then set up a magnetic table that is perpendicular to the bed?
DP: Is your stainless steel magnetic?
Old 02-02-2010, 04:57 AM
*Registered User*
Glacern is on a distinguished road
Grinding on a vertical mill can be done with a flaring cup wheel (typically used for tool/cutter grinders), kind of like a mini Blanchard. As long as the wheel is dressed with a diamond, the results can be decent on small workpieces.
Be careful with the grinding dust and swarf created... you definitely don't want it circulating in your coolant. The hassle of preparation and cleanup is enough to deter many people from trying it. Also, unless the workpiece is hardened, similar/better results can be achieved with a quality facemill.
-Sol
Glacern Machine Tools
Old 02-05-2010, 10:59 AM
Yes my stainless steel magnetic.
Newbie- ISO Surface Grinding Primer r11449 General Metalwork Discussion 2 03-21-2009 12:04 PM
Surface Grinding neilw20 Syil Products 5 08-12-2008 01:27 AM
Why is surface grinding so accurate... WilliamD General Metal Working Machines 11 07-22-2007 06:14 AM
Surface Grinding Woes Zumba General Metalwork Discussion 25 03-20-2007 10:37 PM
Surface Grinding Aluminum? kumaichi General Metalwork Discussion 8 10-31-2006 06:24 AM
