Old 01-29-2010, 02:54 PM
ebydrc is on a distinguished road
welding on machine
ive got a fast question, i need to repair a part that is not removible from the machine, it requires alittle mig welding, im wondering before i do anything is this going to harm my machine?
dont know if it makes a difference but im useing stepper motors
Old 01-30-2010, 04:51 AM
RalcoBe is on a distinguished road
I only know about welding on cars.
It can go wrong, mostly it doesn't
I describe her the reason why it can go wrong:
Welding invokes HF AC currents.
As many know, a battery acts as a wire for HF.
So the currents go throug the wires, and can invoke a dangerous tension over other components like alternators, ecu,...
So it's always safer to disconnect the battery.
In your case, I don't know your setup:
When you disconnect all wires from your machine, leaving the steppers or servos on it, but disconnected, you're safe.
When you weld without disconnecting and keep the mass clamp close to your welding area, you're nearly safe.
Follow also the path of current.
Welding on the X-axis, while having the clamp connected to the machine base, makes the current go througt slides, bearings, spindles... not good.
Old 01-30-2010, 08:46 AM
i had planned out disconnecting all the wiring to and from the machine, i just dont want any problems i would hate to end up replacing stuff from the welding.
Old 01-30-2010, 09:54 AM
In that case, you're safe. Leaving and unconnected motor can't kill him.
Old 01-30-2010, 10:22 AM
KIMFAB's Avatar
KIMFAB is on a distinguished road
Leave your high freq off if your unit is so equipped and it wouldn't hurt to tie all the leads for each motor together and ground them.
I used to be appalled, now I'm just amused.
Old 01-30-2010, 10:31 AM
HF current is invokend, even when not welding with an HF source.
Old 01-30-2010, 10:39 AM
alright thats what i wanted to hear
Old 01-30-2010, 11:03 AM
KIMFAB's Avatar
I was talking about extra high power HF, used by older machines. Comes in real handy when welding light or rusty metal. Plays he!! with my fluorescent lights when I weld with it on.
Modern machines use different methods, such as fancy square waves.
CNC Welding Machine? Kraig1 CNC Plasma and Waterjet Machines 4 05-15-2012 08:22 PM
Welding Machine gaiduldh EBAY ADS 0 01-06-2010 05:28 AM
CNC TIG WELDING MACHINE (Router Type) Khalid General Metal Working Machines 4 07-11-2009 11:11 AM
Tig welding around your machine TT350 Tormach PCNC 11 09-24-2007 08:40 AM
Please Recommend a Home welding machine ThomasAlva Welding, Brazing, Soldering, Sealing 8 08-23-2007 01:34 AM
