Old 01-28-2010, 08:58 PM
ubaldc is on a distinguished road
adapter plate for 8x12 hf lathe
bought a 4 inch 4 jaw chuck from littlemachineshop. since the pilot on the faceplate is fairly short, the holes i drilled in the faceplate are off enough to make bolting the chuck a problem. i would like to get an adapter plate.
anyone know where I can get one?
btw, drilling through that backing plate was a bear. chewed up more than one bit.
thank you,
Chris
Old 01-29-2010, 12:31 PM
whateg01's Avatar
whateg01 is on a distinguished road
When I bought my lathe the spindle did not run true, so I mounted the original backplate and bolted a piece of aluminum to it, turned it to the OD of the chuck with the necessary register and flipped it to fit the existing backplate. Then I turned the chuck side to fit the chuck and drilled/tapped holes and mounted the chuck. I would think for a small lathe like that it would work fine.
Dave
Any good electronics tech knows that 1+1=10.
Just my 2.5 cents.
Old 01-29-2010, 02:03 PM
thank you
as I nurse my finger I smashed on the lathe bed after the drill spun out of my hands, I greatly appreciate comments. now it all makes sense.
i will get some aluminum and solve this problem, sore finger and all.
thank you very much for the quick reply.
Chris
Tags
chuck, hf 8x12, lathe
8x12 (8x14) Lathe Mods TroyO Mini Lathe 11 02-08-2010 06:21 AM
8X12 HF Lathe CNC conversion? Noto Mini Lathe 1 10-22-2008 08:23 AM
DIY QTC for HF 8X12" Lathe?? scubasteve_911 Mini Lathe 20 02-05-2008 05:44 PM
need help with lathe adapter Lionclaw General Metalwork Discussion 5 01-03-2007 07:02 AM
9x20 adapter plate Pxsi Polls 8 10-04-2006 05:32 AM
