Old 01-27-2010, 10:13 PM
Eric MFG is on a distinguished road
KITAMURA TOOL CHANGE PROBLEM
I have a 92 Mycenter1 and having problems with the tool change operation. In MDI mode I call up a pot number the machine responds, when I type in command M6 the pot drops down as should but the spindle spins at 1000 to 1100RPM rather than the slow RPM I’m use to seeing. Then the spindle stops then nothing happens no ARM movement. The same happens when a program is run.
Could someone shed some light on this problem?
Thanks In advance,
Eric
Need Help!- TOOL CHANGE PROBLEM Stebedeff Fanuc 1 03-18-2009 08:23 AM
VF3 tool change problem cata1351 Haas Mills 1 10-18-2007 06:11 PM
FANUC 6M Kitamura mycenter 2 Tool change help Yabbos Fanuc 5 08-09-2007 03:25 PM
Problem in tool change ahmedsamy_81 CNC Machining Centers 5 03-28-2007 03:35 PM
FANUC 6M Kitamura mycenter 2 Tool change help Yabbos Fanuc 2 05-24-2006 11:15 PM
