Old 01-25-2010, 11:05 AM
tiredengr is on a distinguished road
Logan Lathe Conversion
I'm a long term lurker but never posted. I am thinking about a CNC lathe conversion. I have an 11 inch Logan sitting idle; partly because it is the economy model w/o a quick change box or a power cross feed. One advantage of converting this lathe may be the simplicity in mounting a ball screw for the long. axis. Also thinking of machining a new cross slide with a flat top and enough length to mount several tools; one form of automatic tool change.
Comments from anyone with experience on converting this model Logan or similar lathe or their thoughts on such a project will be greatly appreciated.
Thanks...Rod
Trying to buy a Logan lathe FrankieC General Metal Working Machines 1 08-05-2009 09:25 PM
Logan lather Model 825 Rondos Mach Lathe 0 11-30-2008 05:10 PM
CNCing a Logan Lathe Too_Many_Tools Vertical Mill, Lathe Project Log 7 11-28-2008 10:35 PM
Need Help!- Logan 400 to 6561 tail stock adapter santiago lisboa General Metal Working Machines 0 11-25-2008 11:30 AM
I found an old logan 850 lathe for 100 bucks is it worth it? trilect General Metal Working Machines 4 06-29-2005 04:52 PM
