Old 01-20-2010, 02:55 PM
mtcnc is on a distinguished road
Help Please Feeds and Speeds
I’m new to CNC Programming. I am trying to work out speeds and feeds of a 7 tooth carbide milling cutter. The material is mild steel.
The information on the carbide inserts are:-
Vc (m/min) 350 – 150
Fz (mm) 0.05 – 0.15
Ap (mm) 0.1 – 2.0
Dia 63mm
Using formulas I have worked out the following
Vc = 150
Fz = 0.15
Ap = 2
Teeth = 7
Dia = 63
RPM = 793
Feed = 833
It would be much appreciated to have a second opinion on these results before I start machining.
Many thanks.
Old 01-20-2010, 05:24 PM
irving2008 is on a distinguished road
Yes, close enough.... I'd go 750rpm, 800mm/min but like all things you need to experiment with your machine to get a feel for whats its really capable of. Thats a big cutter, you might need to start at slightly slower spindle speed (say 600rpm) and feed rate (say 450mm/min) (that's a feed/tooth of 0.1) and and see how it goes then ramp it up...
A lot will depend on the rigidity of your mill!
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
Old 01-21-2010, 03:36 PM
Thank you
Speeds n Feeds jessbussert WoodWorking 12 06-12-2008 11:09 AM
Feeds and Speeds sjotime! Mach Software (ArtSoft software) 1 02-17-2008 03:46 PM
Help! with Feeds and speeds please! sjotime! Visual Mill 3 02-13-2008 12:56 AM
feeds and speeds porkchop21 Bridgeport and Hardinge Mills 2 08-30-2007 07:52 PM
Speeds and feeds Hack General Metalwork Discussion 2 10-15-2005 10:47 AM
